April 15, 2020, 10:06 |
Heat Flow in a Plate ICEPAK or Fluent
Hello.
I am doing simulations in Icepak (but I can also see the solution on CFD-Post) for calcute heat transfers coefficient. Whem a I have a vertical channel problem with two plates with only one has generation of heat, I don't know how estimates how much heat are been exchanged in the frontal face of plate. In other words, my problem is estimates heat convective flow or flux in the face turned to the other plate which generates power, the summary report shows only the heat that enters the plate. |
convection, heat flow, icepak, post, report |
Some questions about flow boiling simulation in Fluent | beastieboys6 | FLUENT | 8 | November 20, 2017 23:47 |
Heat transfer from a heated plate using fins | pathakamit | FLUENT | 1 | April 30, 2013 04:07 |
Split boundary zone in FLUENT for mass flow | eishinsnsayshin | FLUENT | 1 | January 18, 2013 13:43 |
Question about Laminar flow over flat plate in FLUENT | gaoyitong | FLUENT | 0 | November 26, 2012 22:51 |
What the differences flow equation of Fluent 6.3 and Fluent 12.1 | opehterinar81 | FLUENT | 0 | August 19, 2011 11:55 |
