Fluid-Structure Interaction - problem with stopped calculations |
Marcin
Rep Power: 10 ![]() |
Hi everyone,
I am solving fluid-structure interaction problem using Fluent, Mechanical and System Coupling. After calculation of a certain number of timesteps (over 800) and obtaining the maximum (20) coupling iterations, I cant get further - calculations are kind of stopped. In task manager, the ANSYS applications do not use any resources. I do not obtain any messages - contributing to license or convergence problems, which might cause such situation. Thus I dont have any idea why it is happening; I got typical outputs for succesfull calculations: in Mechanical - "Preparing the mathematical model" and in System Coupling Solution Informations - the convergence data for 20th coupling iteration (which are OK). I was waiting two days but nothing changed, then I restarted the computer and calculations and the problem appeared for the same timestep number. Please give me some suggestions how could I solve such situation Regards Destroy |
Joo-Yeob Lee
Rep Power: 6 ![]() |
Is there any error messages or log files?
Do you mean the analysis shut down abnormally? |
Fluid structure interaction with VOF method utilized in fluent? | mxl9549 | ANSYS | 0 | July 22, 2016 13:40 |
Fluid structure interaction with VOF method utilized in fluent? | mxl9549 | FLUENT | 0 | July 22, 2016 13:39 |
Number of time step in Transient structure for Fluid Structure interaction | YANNAPOL | Structural Mechanics | 1 | July 5, 2015 08:41 |
Fluid Structure interaction | prince_pahariaa | FLUENT | 3 | March 19, 2013 12:16 |
Fluid Structure Interaction | Apollo | Main CFD Forum | 5 | July 4, 2011 16:15 |
