March 30, 2020, 11:54 |
Fill a hollow body for CFD
HS
Rep Power: 11 |
I have the attached geometry. What would be the best way to fill such a body to create a fluid domain for CFD? Thanks Screenshot 2020-03-30 at 15.51.30 2.jpg |
March 31, 2020, 04:48 |
M
Rep Power: 13 |
Create another volume e.g. a cube in such a way, that it overlaps with nearly all of the body you have, except for the very endings of the tube. Now if you use a boolean operation (subtract the volumes from one-another) you will reveice an inner body (which is what you are looking for) and the outer body which you can delete.
This will give you a large part of the whole thing, but not everything. From there I would go and add the missing parts manually if possible. |
[DesignModeler] Using symmetry for a hollow body | aar85 | ANSYS Meshing & Geometry | 0 | October 30, 2018 23:09 |
[ICEM] How can I fill curve body with 3D hexa mesh? | Kosmosisy | ANSYS Meshing & Geometry | 4 | October 16, 2018 11:54 |
[snappyHexMesh] dynamic mesh: rotating body with increasing/decreasing distance to fixed body | mo_na | OpenFOAM Meshing & Mesh Conversion | 3 | July 26, 2016 05:51 |
[ICEM] Creating body on hollow pin fins HS | nse.nico | ANSYS Meshing & Geometry | 5 | December 3, 2014 20:53 |
[DesignModeler] Hollow surface to solid body ?? - radial turbine | pengxudong | ANSYS Meshing & Geometry | 0 | February 24, 2014 13:44 |
