Ansys AQWA Multibody RAO calculation
Old   March 5, 2020, 07:56
Default Ansys AQWA Multibody RAO calculation
Niels van Duijn
nielssievd is on a distinguished road
I am trying to calculate the RAO's of a multibody system(2 bodies) using the hydrodynamic coefficients from Ansys AQWA. In the .LIS file the hydrodynamic coefficients of the body and the coupling interaction coefficients between (Added mass and Radiation damping) between two objects are given. I assume that the interaction coefficients are given by what AQWA lists as the: 'H/I ADDED MASS/DAMPING FOR FORCE ON STR# 1/2'
The problem is I do not know how to interpret the interaction coefficients. What I am currently doing is placing the interaction matrices at the non-diagonal location of the 12x12 matrice. (See attached image)
However, when I calculate the RAO's of both the bodies I get a result which is different compared to the RAO's AQWA gives.
nielssievd is offline   Reply With Quote
Old   June 9, 2021, 09:19
Benjamin M
Benjamin M is on a distinguished road
HI,I have the same problem. Have you solved your problem?
many thanks for the help!
Benjamin M is offline   Reply With Quote
Old   June 9, 2021, 09:23
Benjamin M
Maybe the 'H/I ADDED MASS/DAMPING FOR FORCE ON STR# 1/2' is not real non-diagonal coefficients. It needs to be divided by a coefficient
ansys, aqwa, hydrodynamic coefficient, hydrodynamic interaction, rao
ANSYS Aqwa ECAT/NCEL/COMP Error Jtmannnn18 ANSYS 0 August 1, 2018 18:46
[ANSYS Meshing] Importing Geometry for analysis in Ansys AQWA AlexK ANSYS Meshing & Geometry 1 October 29, 2017 10:19
2-way FSI in Ansys CFX 15 LucasGasparino CFX 3 August 6, 2015 04:17
ANSYS AQWA (mooring + tension leg platform) liladhar ANSYS 0 June 12, 2012 12:54
