problem regarding velodicity expression error
Old   February 23, 2020, 03:23
Question problem regarding velodicity expression error
chodvadiyaharsh is on a distinguished road
respected members of forum
i have perusing a problem regarding velocity in ansys fluent .there is an error as i mention below
my expression is 44[m/s]*(y/10[m/s])**0.133
error:Incorrect expression unit. Expression Unit [m s^-0.867], Required Unit [m s^-1]
i have lots of problem regarding this.please guide me about this
chodvadiyaharsh is offline   Reply With Quote
Old   February 25, 2020, 05:05
Default Units
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
Change 10[m/s] to 10[m]. 10 might be value of velocity but the numbers do not care. [m s^-1] multiplied by [s^0.133] is leading to the incorrect units.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   March 23, 2020, 02:38
Thank you so much for replying me
heartily thanks to you sir............for guding me
i have follow ur guidence which helps me a lot
and also thanks to cfd online forum
velocity expression error
Pressure outlet boundary condition rolando OpenFOAM Running, Solving & CFD 62 September 18, 2017 07:45
error compiling modified applications yvyan OpenFOAM Programming & Development 21 March 1, 2016 05:53
[swak4Foam] installing funkySetFields igo OpenFOAM Community Contributions 1 November 20, 2012 21:16
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 07:25
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
