Using Material Designer for homogenization
Old   February 9, 2020, 21:05
Default Using Material Designer for homogenization
Jwes is on a distinguished road
I am doing a simulation of a ball striking a plate that has a lattice structure within it. (See Plate.jpeg)
The results are shown in (Result.jpg)
I Then took a unit cell and brought it into ANSYS material designer to obtain the effective properties. These will give me the young's modulus (E1, E2, E3), shear modulus (G12, G13, G23) and 3 poison's ratio.
However, when I used these effective properties, my simulation result for the homogenized structure is vastly different. (see homogenize_result.Jpg)
Is this because homogenization only gives the effective elastic properties and not the plastic properties (yield stress vs strain)
*I used the same plastic properties for the homogenized simulation as I did for the actual lattice impact simulation.
Although the simulation was done in ABAQUS, I am posting the question here as I would like to know if anyone has had experience with Material Designer.
Thanks!
Jwes is offline   Reply With Quote
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 22:43
Domain Reference Pressure and mass flow inlet boundary AdidaKK CFX 75 August 20, 2018 06:37
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
error message cuteapathy CFX 14 March 20, 2012 07:45
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 13:02
