Producing Non-Zero Lift Coefficient for NACA 0012 at AOA=0
Old   January 11, 2020, 16:41
Default Producing Non-Zero Lift Coefficient for NACA 0012 at AOA=0
cagesbuild is on a distinguished road
I have been working on validating my CFD skills with a NACA 0012 airfoil (I have tested NACA 2412 and 0015 but had incorrect results) by investigating the Cl and Cd of the airfoil at Various AOA. I achieve this by rotating the base plane associated with the airfoils imported data. Regardless this particular question focuses at AOA=0 and thus a NACA 0012 should have cl = 0. Where as in my most recent test CL=-0.099067769 and Cd =0.87579035.
The Cl would have been acceptable at with an unrefined mesh but I don't think the quantity of cells (see attached) can be deemed "unrefined". Additionally the left far field is 5 chord lengths from the leading edge and the right far field is 10.
I am using the K-W (SST) Turbulence model with default values (5% intensity and 10 ratio) at 5 m/s.
I am the Coupled pseudo-transient method with all parameters set to "Second-Order Upwind". I used the standard initialization with default reference values and iterated to 1000.
I am not sure what the issue is with either the mesh or the solver, maybe I tweaked something I shouldn't have? Any insight into what the problem is and a solution thereof would be greatly appreciated.mesh Shown.jpg
cagesbuild is offline   Reply With Quote
Old   January 14, 2020, 18:53
Solved: It seems that the voracity viscosity ratio was too high. Following
https://www.reddit.com/r/CFD/comment...ce_validation/
With validation from:
https://turbmodels.larc.nasa.gov/naca0012_val_sa.html
NACA 0012 Coefficient of Lift and Drag Calculations Antang808 FLUENT 1 February 19, 2019 05:26
wrong SU2 calculation for lift and drag coefficient for NAC4421 mechy SU2 7 January 9, 2017 06:18
Drag and Lift coefficient (NACA 0012) remi_fr STAR-CCM+ 17 March 2, 2015 17:23
NACA 0012 lift and drag coefficient. Tom Lucius Main CFD Forum 6 March 29, 2012 07:40
Automotive test case vinz OpenFOAM Running, Solving & CFD 98 October 27, 2008 09:43
