Maintaining (P inlet) constant in Ansys Fluent |
January 6, 2020, 05:04 |
Rep Power: 7 |
In Ansys fluent, during the simulation of an upward fluid flow through a vertical tube (which has a complicated geometry and variable fluid rheology characteristics), we have the boundary condition at the outlet (P_out) then using simulation, we get the results at the inlet (P_in). then, we will play on the rheology and some other conditions, so that the simulation result (P_in) will change.
To control and maintain the pressure at the inlet (the result of the simulation) constant, we want to adjust and play on the the boundary condition (P_out). ......... My question is... can i estimate the values of (P_out) so that (P_in) stays constant. And How? Thanks in advance. Last edited by Belimane; January 6, 2020 at 10:55. |
January 31, 2020, 06:09 |
Clarity!
The question is not very clear. If inlet pressure is required to be constant, you may just set it as Pressure Inlet Boundary Condition. If you want static pressure to be constant at the inlet, then set a value of total pressure, go to initialization tab, enable standard initialization, and choose Inlet boundary under Initialize From. It will calculate static pressure and show the value. Modify the total pressure until you get the desired value.
Please provide more description, if I have misunderstood your requirement.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 06:38 |
Inlet definition in VOF | TALEMWA EMMANUEL | Fluent Multiphase | 1 | September 7, 2019 12:32 |
Inlet Mixing at 1D Numerical Model | Stratified Storage | HumanistEngineer | Main CFD Forum | 26 | July 30, 2018 11:41 |
How to keep the water level constant at inlet | Tanjina | FLUENT | 10 | January 21, 2016 11:29 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 06:13 |
