Multiple surface reaction model - surface combustion
Old   December 28, 2019, 15:07
Default Multiple surface reaction model - surface combustion
Jacob
Mechand is on a distinguished road
Hello everyone,
I have some doubts regarding the multiple surface reaction model of Smith.
In other models (kinetic/diffusion, intrinsic, diffusion) we specify heat of reaction for burnout and stoichiometric ratio. In multiple surface reaction model we do not.
Can anyone explain to me why?
In the User guide I found that: "You will notice that the Burnout Stoichiometric Ratio and Heat of Reaction for Burnout are no longer available in the Create/Edit Materials dialog box, as these parameters are now computed from the particle surface reactions you defined in the Reactions dialog box."
But the question is how are they computed !! And does this mean that for the other models only the combustion reaction is considered? But I still can define other particle reactions for other models too in Reaction dialog box.
What if I define a reaction in the reaction dialog box that is endothermic? How will fluent know that it is endothermic?
All the best in the New Year 2020!
Thanks in advance
Last edited by Mechand; December 28, 2019 at 18:37. Reason: extended description of the problem
Mechand is offline   Reply With Quote
CFD analaysis of Pelton turbine amodpanthee CFX 31 April 19, 2018 19:02
Detailed Chemical reaction over combustion model jaychhatbar AVL FIRE 1 June 23, 2017 14:13
Combustion Model - Laminar Flamelet Model spg1g14 CFX 0 August 5, 2015 19:13
problem with solving lagrange reaction cloud Polli OpenFOAM Running, Solving & CFD 0 April 30, 2014 08:53
[snappyHexMesh] Layers don't fully surround surface EVBUCF OpenFOAM Meshing & Mesh Conversion 14 August 20, 2012 05:31
