December 17, 2019, 07:03 |
Semisubmersible Ansys Aqwa Meshing Error
I have tried to mesh a semisubmersible geometry in Ansys aqwa through hydrodynamic diffraction. As i run the solution i get the error:
1)elements must be at least 1.000x Facet radius apart. 2)The ratio of the areas of adjacent elements must be less than 0.333 to avoid this i enable the GOON option KrogerFeedback which means it avoids the errors but it gives me the following error for a number of elements. UNDERWATER SIDE # 1 ON ELEMENT#21133 IS NOT CONNECTED TO ANOTHER ELEMENT. THIS MAY CAUSE PRESSURE ERRORS AND WILL CAUSE HULL PRESSURE CONTOUR ERRORSI have checked the mesh it does look good. has triangular elements and is within the element limit. they are all connected to node points. Is there any other way to bypass this issue of meshing. Last edited by denwlein; December 18, 2019 at 08:15. Reason: spelling |
Pressure outlet boundary condition | rolando | OpenFOAM Running, Solving & CFD | 62 | September 18, 2017 06:45 |
[OpenFOAM] Native ParaView Reader Bugs | tj22 | ParaView | 270 | January 4, 2016 11:39 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 19:43 |
[swak4Foam] installing funkySetFields | igo | OpenFOAM Community Contributions | 1 | November 20, 2012 20:16 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 06:42 |
