December 15, 2019, 03:38 |
Semisubmersible Ansys Aqwa Meshing Error
neklein
I have tried to mesh a semisubmersible geometry in Ansys aqwa through hydrodynamic diffraction. As i run the solution i get the error:
1)elements must be at least 1.000x Facet radius apart. 2)The ratio of the areas of adjacent elements must be less than 0.333 to avoid this i enable the GOON option which means it avoids the errors but it gives me the following error for a number of elements. UNDERWATER SIDE # 1 ON ELEMENT#21133 IS NOT CONNECTED TO ANOTHER ELEMENT. THIS MAY CAUSE PRESSURE ERRORS AND WILL CAUSE HULL PRESSURE CONTOUR ERRORSI have checked the mesh it does look good. has triangular elements and is within the element limit. they are all connected to node points walmartone. Is there any other way to bypass this issue of meshing. Last edited by pelwein; December 17, 2019 at 08:12. Reason: Spelling |
[OpenFOAM] Native ParaView Reader Bugs | tj22 | ParaView | 270 | January 4, 2016 11:39 |
Errors in UDF | shashank312 | Fluent UDF and Scheme Programming | 6 | May 30, 2013 20:30 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
Compiling problems with hello worldC | fw407 | OpenFOAM Installation | 21 | January 6, 2008 17:38 |
