December 11, 2019, 12:28 |
Semisubmersible Ansys Aqwa Meshing Error
melrin
I have tried to mesh a semisubmersible geometry in Ansys aqwa through hydrodynamic diffraction. As i run the solution i get the error:
1)elements must be at least 1.000x Facet radius apart. 2)The ratio of the areas of adjacent elements must be less than 0.333 to avoid this i enable the GOON option which means it avoids the errors but it gives me the following error for a number of elements. UNDERWATER SIDE # 1 ON ELEMENT#21133 IS NOT CONNECTED TO ANOTHER ELEMENT. THIS MAY CAUSE PRESSURE ERRORS AND WILL CAUSE HULL PRESSURE CONTOUR ERRORS I have checked the mesh it does look good. has triangular elements and is within the element limit. they are all connected to node points. Is there any other way to bypass this issue of meshing. |
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries | NickG | OpenFOAM Installation | 3 | December 30, 2019 01:21 |
[swak4Foam] installing funkySetFields | igo | OpenFOAM Community Contributions | 1 | November 20, 2012 21:16 |
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) | Yogini | Fluent UDF and Scheme Programming | 7 | October 3, 2012 08:24 |
CGNS lib and Fortran compiler | manaliac | Main CFD Forum | 2 | November 29, 2010 07:25 |
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." | sega | OpenFOAM Community Contributions | 12 | February 17, 2010 10:30 |
