mass sping damper system inside floating strcuture |
December 4, 2019, 05:58 |
Ruud Caljouw
Rep Power: 13 |
Hi All,
I am trying to solve the behaviour of a floating structure on the ocean waves with a spring mass damper system inside the floating structure. Is there a way to model this in CFX or fluent. Solving only the floating structure is no problem using de VOF method with the rigid body solver. But in this case there is a second mass connected to the floating body via a spring and a damper, which affects the dynamics. This second mass is not influenced by the fluid whatsoever. Can anybody point in the right direction. Thanks. |
external connection, floating body, spring-mass system |
regarding simulation of heat and mass transfer inside thermosyphon | 1757003@kiit.ac.in | ANSYS | 1 | May 14, 2019 02:06 |
Match Pressure Inlet/Outlet Boundary Condition Mass Flow Rate | MSchneid | Fluent UDF and Scheme Programming | 3 | February 23, 2019 06:00 |
Mass Increase for closed system with moving wall | Evan | FLUENT | 2 | April 21, 2015 15:14 |
CFX11 + Fortran compiler ? | Mohan | CFX | 20 | March 30, 2011 18:56 |
meshing F1 front wing | Steve | FLUENT | 0 | April 17, 2003 12:37 |
