Fluent simulation In parallel ,which way is faster ?! |
December 2, 2019, 04:04 |
Os
Rep Power: 9 |
Hello ,
I am making a Simulation CFD (2D) using ansys fluent and i have a workstation with 24 physical cores that supports hyper threading (48 cores), but i am still hisitating about runing my simulations on both real and logical cores because i ve read an article that says hyperthreading is only gonna slower the calculations ( not sure if this is true). Does anyone have any idea about which way is faster using only 24 cores (only physical ones ) or using both ( with hyper threading 48 cores )? Many thanks to you all . |
December 2, 2019, 14:29 |
Erik
Rep Power: 23 |
Do you have the HPC licenses to run 48 cores?
Why not just run a quick benchmark to find out? I've read using hyperthreading and double the cores makes it just slightly faster (20%) for Fluent. But I have never done the test myself, and this would also be a waste of HPC licenses. |
December 2, 2019, 14:53 |
#3 | |
Os
Rep Power: 9 |
Hello , What do you mean by HPC licence? My workstation is a HP Z820 with Cracked Version of Ansys .Can you please explain further Regards |
Parallel simulation on STAR-CCM+ 11.06.010-R8 | Hosseinmgh_chemeng | Siemens | 1 | August 30, 2017 08:21 |
Explicitly filtered LES | saeedi | Main CFD Forum | 16 | October 14, 2015 11:58 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 18:45 |
Interesting problem: Parallel Processor VOF Fluent + Dynamic Mesh + System Coupling | spaceprop | FLUENT | 5 | September 2, 2014 09:43 |
LSR (Land speed record) car simulation on FLUENT | Maxime31850 | FLUENT | 2 | May 1, 2013 11:15 |
