November 17, 2019, 04:58 |
Which analysis type do i use?
Ataberk
Rep Power: 6 |
Hi, I am a student and I try to learn Ansys Fluent. I have a project and want to see approximately how much pressure is it needed to swell. Which analysis type do i use? It is elastic, therefore i am confused.
Here is the link: https://www.youtube.com/watch?v=GgJt6vIbiso (If you do not wonder how it is made, you can watch the last minute.) |
November 18, 2019, 04:04 |
Gert-Jan
Rep Power: 28 |
I doubt if this can be done using Fluent. The flow is not so interesting here. The shape (i.e. deformation) is not determined by flow but by the pressure. So you'd better focus on the mechanical part. Not sure what mechanical software can do this.
November 19, 2019, 16:01 |
Erik
Rep Power: 23 |
Not CFD software, as Gert-Jan says.
This would be a mechanical analysis with geometric non-linearities, and probably material non-linearities included. Most commercial FEA packages should be able to do this. ANSYS mechanical static-structural for one. Transient-Structural is not needed, as inertia is not a role here for the most part. |
ansys 19.2, elastic analysis, elastic deformation, pressure coefficient |
natural convection in square cavity having inlet and outlet | sujeet | OpenFOAM Running, Solving & CFD | 1 | November 2, 2019 02:17 |
[Other] simulation of closing the gate using moving mesh | simin_ds | OpenFOAM Meshing & Mesh Conversion | 8 | April 12, 2019 05:49 |
boundary conditions for simpleFoam calculation | foam_noob | OpenFOAM Running, Solving & CFD | 8 | July 1, 2015 08:07 |
[GAMBIT] periodic faces not matching | Aadhavan | ANSYS Meshing & Geometry | 6 | August 31, 2013 11:25 |
[swak4Foam] Air Conditioned room groovyBC | Sebaj | OpenFOAM Community Contributions | 7 | October 31, 2012 14:16 |
