Liquid Injection into Hot Gas Combustion Chamber
Old   November 13, 2019, 15:15
Default Liquid Injection into Hot Gas Combustion Chamber
Scott Thomas
scowaltho is on a distinguished road
I am looking to model an application of liquid injection into a hot gas combustion chamber, where it vaporizes, decomposes, and reacts with the hot gas flow. The injected liquid is nitromethane, and the hot gas temperature is about 3000 K. The main goal of the analysis is to estimate internal surface heat fluxes which will be used for thermal analysis and design.
We're looking at using Ansys Fluent for this. Would Fluent be a good tool for this type of simulation? If not, what tool would be recommended? If so, can you recommend any resources/examples/papers that describe similar simulations that I could look at to get a better idea how to set up something like this?
scowaltho is offline   Reply With Quote
combustion, injection, liquid, multiphase
Injection of gas into tube with small holes - Supersonic flow mrsl Main CFD Forum 0 December 5, 2018 07:49
Chamber non-premixed combustion pressure Hawxliquid FLUENT 0 March 16, 2017 13:37
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 02:27
combustion flow simulation in liquid rocket thrust chamber geetha sri FLUENT 1 February 4, 2016 18:04
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 23:02
