CFD: Pressure loss over an engine valve
Old   October 21, 2019, 13:18
Question CFD: Pressure loss over an engine valve
Matt
mrich211 is on a distinguished road
I'm trying to model the flow through a valve port and around an engine valve into a cylinder chamber, which flows around a wide piston rod/trunk (like an annulus). Specifically, I'd like to know the pressure loss as the fluid moves around the open valve and enters the cylinder.
I'm having trouble defining a mesh around the valve CAD geometry (inside the valve port and around the head into the cylinder) as it is open space. I'm quite new to ANSYS, does anyone know how I'd do this?
If you imagine you had to simulate flow around a pencil inside of a hollow tube, which connected to a hollow cylinder, how would you mesh that fluid domain?
Thanks.
mrich211 is offline   Reply With Quote
cfd analysis, engine simulation, fluid domain, geometry, valve simulation
Wind tunnel Boundary Conditions in Fluent metmet FLUENT 6 October 30, 2019 13:23
Autodesk CFD Duct pressure loss Kasper H Autodesk Simulation CFD 1 June 15, 2018 10:18
CFD by anderson, chp 10.... supersonic flow over flat plate varunjain89 Main CFD Forum 18 May 11, 2018 08:31
Periodic flow using Cyclic - comparison with Fluent nusivares OpenFOAM Running, Solving & CFD 30 December 12, 2017 06:35
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 03:15
