Rep Power: 0 ![]() |
In Workbench 18.1 I have set up my geometry and mesh, before opening Fluent and selecting all my settings. Whilst selecting the settings, sometimes, if I click on the mesh of the part, I get the error;
" cx1810.exe has stopped working. A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available." With two possible options - either debug or close program. It causes the program to close and any unsaved changes are lost. This isn't happening every time I click on the mesh and if I reopen the project to carry on it is fine. If anyone has any suggestions that would be really great. Thank you. |
cx1810.exe, error 1810 |
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries | NickG | OpenFOAM Installation | 3 | December 30, 2019 00:21 |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 09:00 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
