Surface vortex in sump pump tank
Old   August 13, 2019, 14:01
Default Surface vortex in sump pump tank
Ali Kadhim
Alikadhim is on a distinguished road
I am trying to simulatue the probability of happening surface vortex in sump pump tank by vertical pipe.
I need to set the velocity in the bell mouth of intake as 1.5 m/s as constant velcity. And the depth of water in the tank must be constant.
I set one of tank faces as mass-flow inlet with constant water surface. Also i use VOF ans set open channel.
Also i set the bell mouth of suction pipe as velocity inlet and the outlet of the pipe as pressure outlet of zero gage pressure.
Is the B.C. that I used is true?
What is the right B.C. to get the simulation appear the vortex in the animation.
Best regards.
Alikadhim is offline   Reply With Quote
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 12:12
[snappyHexMesh] snappyHexMesh generates not planar surface krzychu111 OpenFOAM Meshing & Mesh Conversion 2 April 23, 2020 17:38
Closed rotating tank with free surface Juan Catelén CFX 1 October 10, 2007 19:59
curve of vortex of free surface in mixing tank bioman66 CFX 1 June 30, 2006 07:19
Free surface vortex flow Guillaume CFX 3 August 25, 2005 21:52
