Workbench results not matching CFD-Post
Old   July 3, 2019, 21:59
Default Workbench results not matching CFD-Post
Newbie
newbietocfd is on a distinguished road
Hi all, I hope somebody can help me with this issue. I have a CFD model, run using CFX via Workbench. The model has rotation as an input parameter, drag force/projected areas as output parameters. The model was running with no issue using ANSYS 19.2.
I upgraded into 2019R2, and for some reason I see that the results in Table of Design Points in Workbench do not match the results that I see in CFD-Post. It seems to me that the Workbench results also rotate the axes, e.g. the projected areas are now the same regardless of the rotation, and the force results are switched at 90 degree (e.g. in CFD-Post, I get X and Y values, but it was shown as Y and X values in Workbench parameters table).
Does anyone know if I miss some steps? I checked each input and it is consistent between 19.2 and 2019R2. Sorry if it turns out to be an obvious one since I am still new learning CFD. Thank you in advance.
newbietocfd is offline   Reply With Quote
Old   December 4, 2019, 12:55
sheaker's Avatar
Oskar
sheaker is on a distinguished road
Hello.
I think I have similar problem. Did You found solution already? Could You, please, take a look at my thread?
I can't make my body rotating in transient structural
Regards,
Oskar
sheaker is offline   Reply With Quote
cfx, workbench
Fluent export - CFD Post - Airfoil Results Wingman ANSYS 0 November 18, 2016 17:36
Collect transient results CFD POST mortain CFX 15 April 17, 2015 09:29
differenciate the symmetry and periodic results in cfd post Vidyanand Kesti FLUENT 0 November 8, 2013 09:22
FEA results in CFD Post delaneyluke CFX 1 October 25, 2013 07:16
CEL mathematical functions in CFD Post Jonathan CFX 9 November 5, 2012 09:37
