Y plus display in CFD-Post in a conjugate problem |
June 26, 2019, 00:14 |
Harry Zhang
Rep Power: 11 |
Hey everyone. I have a question about displaying a contour of y plus in a conjugate problem. The problem consists of two flow channels in a solid. After the computation, I can display the y plus contour plot in Fluent. I select the surface in the fluid domain, which is usually named "contact_src" in ANSYS. But when I want to do the same thing in CFD-Post, it just doesn't show up anything. However, if I try the contours of other properties like temperature, pressure or velocity on the surface "contact_src", they show up with no problem. I attach the pictures of the y plus contour in Fluent graphics (it shows up) and in CFD-Post (it doesn't). Any idea why this happens?
Thanks |
June 26, 2019, 03:12 |
M
Rep Power: 13 |
It should be there I think. Is this a full result file you are looking at? If its a transient result, maybe yplus is not included in the output and can't be displayed.
June 26, 2019, 18:31 |
Harry Zhang
Rep Power: 11 |
It is a steady state result. The calculation is complete. Is it because of the nature of the conjugate heat transfer problem?
Problem in CFD -post | pratikvn | ANSYS | 4 | March 21, 2018 03:56 |
[ANSYS Meshing] Displaying solid domains in CFD Post without meshing them. | hda | ANSYS Meshing & Geometry | 5 | October 24, 2016 10:26 |
static enthalpy calculation in CFD Post | newbie384 | CFX | 2 | March 22, 2014 08:28 |
CFD Post Streamlines better representation? | Dr. Flow Squad | CFX | 2 | January 20, 2014 14:48 |
errors when installing openfoam2.1 on ubuntu12.o4 | hewei | OpenFOAM Installation | 5 | May 29, 2012 08:43 |
