Problem in generating mesh for pipe
Old   June 3, 2019, 11:30
Default Problem in generating mesh for pipe
Hadi
hadkam90 is on a distinguished road
Hi every one.
I want to model elbow erosion with fluent. The reference paper generate a mesh like the uploaded picture. How can I create mesh like it?
Tahnks alot.
http://s000.tinyupload.com/?file_id=...33644424838436
hadkam90 is offline   Reply With Quote
Old   June 14, 2019, 20:40
jey
jeytsav is on a distinguished road
Hi Hadkam90,
This is the o-grid kind of mesh you would like to generate.
You can do this in ANSYS meshing by following the steps below
1. Add a Multizone method to your pipe.
2. Add a Face meshing control to the cylindrical face of interest. Ensure that Mapped mesh is switched to "On"
3. Right click on the Multizone method and select "Inflate this method". Then specify the desired number of inflation layers you would like to have.
4. Generate mesh.
https://www.dropbox.com/s/0pyrznadz9..._mesh.PNG?dl=0
Best,
Ioannis
jeytsav is offline   Reply With Quote
Old   June 17, 2019, 14:32
Erik
evcelica is on a distinguished road
Or you can slice your geometry into a square and the four 45 degree angles, then "create part" in ansys design modeler.
Then use line sizing mesh commands and mapped face meshing. to achieve your desired mesh.
evcelica is offline   Reply With Quote
Old   June 19, 2019, 16:12
Mayank
May19 is on a distinguished road
https://www.youtube.com/user/turboengineern/playlists
if you are using ansys meshing and cfd
https://www.youtube.com/watch?v=B7BdQnuutnQ
if you are using ICEM
May19 is offline   Reply With Quote
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
[TGrid] Problem when generating volume mesh "tg-is-point-in-region" Tuck ANSYS Meshing & Geometry 1 April 16, 2017 13:19
[snappyHexMesh] SHM problem : KVLCC2 with appendage mesh sc.park OpenFOAM Meshing & Mesh Conversion 1 March 13, 2016 14:28
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 07:42
[ICEM] Problem making structured mesh on a surface froztbear ANSYS Meshing & Geometry 4 November 10, 2011 09:52
