how to access species molar weight in DEFINE_DIFFUSIVITY macro?
Old   June 3, 2019, 00:51
Default how to access species molar weight in DEFINE_DIFFUSIVITY macro?
Weiqiang Liu
Weiqiang Liu is on a distinguished road
Hi all,
I wanna define my own diffusion coefficient with DEFINE_DIFFUSIVITY macro. I need species molar weight to calculate effective diffusion coefficient. however, I don't want to set molar weight as constant. I want to loop all species molar weight with species index i.
I wonder is it doable in fluent. If it is, how can I do that?
Best regards.
Weiqiang
Weiqiang Liu is offline   Reply With Quote
Old   March 3, 2020, 08:44
Tamil Nadu
Sowmiya is on a distinguished road
Hi Sir
Did you find a solution? If so Can you suggest how to do?
I too face the same issue.
Please kindly give me few suggestions.
Regards
Sowmiya
Sowmiya is offline   Reply With Quote
Old   March 3, 2020, 10:46
Default Molecular Weight
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
The solution to this is available within Fluent's UDF manual. Properties of species are indexed and can be accessed using indices starting with PROP_, e.g., PROP_mwi for molecular weight. Do note that these are only indices and need to be used as argument for the function generic_property to fetch the value of the property. Look for generic_property within Fluent UDF manual.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   March 3, 2020, 15:37
Tamil Nadu
Thank you for the instant reply. i will carry out your suggestions and let you know.
Thanks
Sowmiya
Old   April 25, 2020, 04:46
Lee Jo
the_sixth_hokage is on a distinguished road
Hi is there any macros for accessing other properties such as critical temperature, critical volume, molecular weight etc of species...
I can't seem to find it in manuals...do you have any links to PDFs or sites?!
the_sixth_hokage is offline   Reply With Quote
How to access species molecular weight in UDFs Ellen FLUENT 3 June 2, 2019 20:55
Macro to access java files in sub-directory abraum STAR-CCM+ 3 July 11, 2012 03:46
UDF Data Access Macro Woo Meng Wai FLUENT 0 November 6, 2007 21:23
direct access to species greg Main CFD Forum 3 July 15, 2006 05:37
Macro to access mean variables Dragos FLUENT 2 February 2, 2005 12:30
