A general failure occurred during the solution process.
Old   May 21, 2019, 11:39
Default A general failure occurred during the solution process.
Dimitrios S. P.
Pled is on a distinguished road
I am trying to run explicit dynamics, but after AUTODYN PRE-SOLVER SETUP is complete the solution stops and the following message is displayed "A general failure occurred during the solution process."
I have installed the same ansys version on another pc and everything works ok. RAM is the same, processor is the same, both nvidia GPUS.
What could cause such an error?
Pled is offline   Reply With Quote
Old   May 23, 2019, 10:53
Dimitrios S. P.
I have tried to open aytodyn component from workbench but the following message appears.
"System.ComponentModel.WarningException: Interprocess Communications failed to establish with the AUTODYN Application.
You may have to close the application by hand.
at Ansys.AUTODYN.Commands.AUTODYNIPC.StartIPC(IFullCo ntext context)
at Ansys.AUTODYN.Commands.AUTODYNIPC.StartAUTODYNProc ess(String adExeFilePath, String arguments, String dir)
at Ansys.AUTODYN.Commands.AUTODYNIPC.StartAUTODYN(Boo lean bUseDoublePrecision, String dir)
at Ansys.AUTODYN.Commands.EditSetup.StartAUTODYNWithF ileForSolution(AUTODYNSolutionDataObject solnDataObject, String newFilePath, AUTODYNIPC ipc, String cwd)
at Ansys.AUTODYN.Commands.EditSetup.Execute(IFullCont ext context)
at Ansys.Core.Commands.Concurrency.CommandWorkUnit.ex ecuteInContext(CommandContext subContext, IExecutionEngineCallback tracer)
at Ansys.Core.Commands.Concurrency.BaseWorkUnit.doExe cute(IExecutionEngineCallback executionEngine, CommandContext subContext)
at Ansys.Core.Commands.Concurrency.BaseWorkUnit.Execu te(IExecutionEngineCallback executionEngine, Boolean dontCatchExceptions)
--- Ansys.Core.Commands.CommandFailedException: Interprocess Communications failed to establish with the AUTODYN Application.
CommandName: Autodyn.Edit(Container="Setup 3")
at Ansys.Core.Commands.CommandAsyncResult.RethrowFail ureException(Exception e)
at Ansys.Core.Commands.CommandAsyncResult.Wait(Int32 milliSecondsTimeout, Boolean exitContext)
at Ansys.AUTODYN.Commands.EditSetup.InvokeAndWait(IPr otectedContext context, DataContainerReference Container)
at Ansys.AUTODYN.GUI.ActivateModelEditing.Invoke(GuiO perationContext context)
at Ansys.UI.GuiOperationContext.Invoke(GuiOperationMe taData operationData)
at Ansys.UI.UIManager.InvokeOperationCore(String pseudoname, OperationDelegate callback, Boolean allowOSMessages, Boolean coreTransaction)"
error, explicit dynamics
Trying to perform test validity of Fluent with simulation of 2D airfoil didiean FLUENT 39 December 5, 2015 14:31
ERROR #001100279 has occurred in subroutine ErrAction. sujay CFX 8 December 10, 2014 13:09
Naca 0012 (compressible and inviscid) flow convergence problem bipulsaha FLUENT 1 July 6, 2011 08:51
General Unsteady solution convergence Freeman Main CFD Forum 0 December 7, 2005 18:08
Wall functions Abhijit Tilak Main CFD Forum 6 February 5, 1999 02:16
