February 20, 2019, 15:13 |
Parameter set in Hydrodynamic Diffraction
Ingrid Pacheco Silveira
I'm trying to run a simulation at Hydrodynamic Diffraction (AQWA) using Parameter Set to modify the dimensions of my model. I've already drawn my structure in Design Modeler. When I run my simulation, I can get the results for my main structure (DP 0). But when I try to run the simulations for the other design points, ANSYS shows me warnings and errors messages in the attached file. Do you guys know what might be wrong in my routine? I am using the 18.1 version of ANSYS/AQWA. |
ansys, aqwa, design points, parameter set |
[ICEM] ICEM Scripting Issues | tylerplowright | ANSYS Meshing & Geometry | 33 | September 27, 2021 17:35 |
Ansys SIG$ILL error | loth | ANSYS | 3 | December 24, 2015 06:31 |
[PyFoam] running pyFoam(Plot)Runner.py in parallel | Studi | OpenFOAM Community Contributions | 10 | September 6, 2015 17:38 |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 14:43 |
Env variable not set | gruber2 | OpenFOAM Installation | 5 | December 30, 2005 05:27 |
