February 15, 2019, 03:19 |
fluid structure interaction error
bikash sahoo
Dear all
i am doing a arterial flow simulation using two way FSI ansys simulation. i have used the artery as transient structural model and blood as fluent model. for the fluid inlet i have used a pulsating flow and used a UDF and outlet as pressure outlet. after i couple the solid and fluid and tried to run the simulation i am getting the below error. i am new to ansys. your valuable suggestion will be highly helpful. one screen shot of above error is also attached. thank you. ================================================== ==================== +================================================= ===================+ | | | Solution | | | +================================================= ===================+ ================================================== ==================== +--------------------------------------------------------------------+ | MAPPING SUMMARY | +--------------------------------------------------------------------+ | Data Transfer | | | Diagnostic | Source Side Target Side | +----------------------------------+---------------------------------+ | Data Transfer | | | Percent Nodes Mapped | N/A 100 | | Data Transfer 2 | | | Percent Nodes Mapped | 100 100 | | Percent Area Mapped | 100 100 | +--------------------------------------------------------------------+ +================================================= ===================+ | COUPLING STEP = 1 SIMULATION TIME = 1.00000e-002 | |--------------------------------------------------------------------| | Solver | Solution Status | | Data Transfer | | | Diagnostics | Source Side Target Side | +================================================= ===================+ +================================================= ===================+ | NOTICE | | An exception has occurred and has been transmitted to the coupling | | participants. These participants have been disconnected from the | | coupling service. | +================================================= ===================+ +================================================= ===================+ | System Coupling Exception | +================================================= ===================+ | Origin : Transient Structural (Solution) | | Error Code : 2 | | Error Description : | | Solution not converged at time 1.E-02 (load step 1 substep 1). | | Run terminated. | +================================================= ===================+ System coupling run completed with errors. |
[OpenFOAM] an error in Calculator's equation | immortality | ParaView | 12 | June 29, 2021 01:10 |
Compiling dynamicTopoFvMesh for OpenFOAM 2.1.x | Saxwax | OpenFOAM Installation | 25 | November 29, 2013 06:34 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 07:42 |
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." | sega | OpenFOAM Community Contributions | 12 | February 17, 2010 10:30 |
user subroutine error | CFDUSER | CFX | 2 | December 9, 2006 07:31 |
