Draining tank analysis
Old   February 12, 2019, 08:55
Default Draining tank analysis
Lorenzo
lorenzoalari is on a distinguished road
Hi everyone,
I am a new user, eager to learn as much as possible from all of you :-)
I am facing a problem which is causing me some troubles.
My goal is to estimate the flow rate through a vertical pipe connected to a tank, simulating the emptying of the latter. So, basically it's a gravity problem with 0 pressure on the free surface of the oil and on the discharge section of the nozzle. I employed a viscous-laminar model with energy activated. Gravity is of course enabled. Even though I should use a transient solution, it requires way too long for the solution to converge (for all the oil in the tank to drain). Hence I studied the problem with a steady approach. I specified all the oil properties in the materials section, writing them as functions of temperature.
What I'd like to know is:
- how do I deal with the Bussinesque's parameters? If I do not check the "operating density" box in the cell zone condition, the solution converges at the very first iteration, providing me zero flow rate. If I check that box, which density should I give as input?
- Should I specifically express the zero-pressure location in the "cell zone conditions" menu even though I've already specified the pressure inlet/outlet in the boundary conditions?
Ciao,
Lorenzo
lorenzoalari is offline   Reply With Quote
fluid, oil, tank
How to implement a sensitivity analysis for certain items Mason liu CFX 10 August 17, 2017 09:46
Pressure Temperature Evolution in Tank Venting by VOF model-FLUENT avi@lpsc Main CFD Forum 0 August 4, 2014 07:25
Flow analysis in an enclosed tank lee87 Main CFD Forum 0 March 30, 2014 03:37
Surge tank sachin Main CFD Forum 0 November 18, 2005 08:42
CFD analysis of Fluid Flow over a Weir in a Tank. ronan moore Main CFD Forum 2 February 4, 2005 08:15
