Ball Valve using UDF
Old   February 6, 2019, 10:19
Default Ball Valve using UDF
TUB
yitz
TUB is on a distinguished road
Hi everyonev. I want to simulate a ball valve in Ansys Fluent without creating a physical barrier.
I'm interested in having flow when point A's temperature is above 90°, and stopping the flow (by defining certain conditions at point B) when the temperature is below 75°.
Does anybody know which type of UDF is relevant? And what should I define in order to receive the imaginary barrier at point B?
Thank you!
TUB is offline   Reply With Quote
Fluent Radiation/porous media Schmitt pierre-Louis FLUENT 26 September 1, 2016 11:29
Issues with UDF for ball movement inside a valve A.Jalal Fluent UDF and Scheme Programming 1 July 30, 2015 02:11
UDF for ball motion inside a valve. A.Jalal Fluent UDF and Scheme Programming 0 July 29, 2015 15:17
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 23:14
CFD in sports David Howell Main CFD Forum 21 July 12, 1999 07:31
