January 19, 2019, 05:28 |
LS-Dyna material error in Workbench
Rep Power: 8 |
if i use the LS-Dyna solver (instead of Autodyn) with my predefinied ansys Johnson-cook damage and failure model in Ansys, Dyna use only *MAT_SIMPLIFIED_JOHNSON_COOK command without my failure parameters instead of *MAT_JOHNSON_COOK .
however afterwards i can make keyword snippet but it looks useless, its simply ignores it. So the question is can i somehow replace or expand the original material ? Or does it exist a command something like that that the solver should use the material which defined with keywords snippet afterwards? for a more simplified example : the solver will not start until i define at least the elasticity of the material, but i can not change it later with keyword snippets, or can i? so in my .k file looks like this: material from database: *MAT_ELASTIC $ ID ro E pr da db k unused1 1 7.85E-09 200000 0.3 0 0 0 and at the end my command: $----------------------------------------------------------------------------- $---------------- COMMAND SNIPPETS ---------------------------------------- $----------------------------------------------------------------------------- *MAT_ELASTIC $ ID ro E pr da db k unused1 1 7.85E-09 70000 0.3 0 0 0 *END and it always took the first values. I can not directly edit the .k file because it show me thats its simply an output file so every start will be rewritten by Ansys. |
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 22:43 |
Domain Reference Pressure and mass flow inlet boundary | AdidaKK | CFX | 75 | August 20, 2018 06:37 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 06:21 |
error message | cuteapathy | CFX | 14 | March 20, 2012 07:45 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 09:56 |
