January 15, 2019, 10:56 |
Assign new properties after meshing
Hi there,
I have a plate with the dimensions 100x100 cm and the thickness varies. The thickness was tested every 1 cm and documented in a 100x100 matrix. I would like to do a buckling analysis and use the accurate thicknesses of the plate for that. Is there is a command, with which I can assign after the meshing each sub-element a new individual thickness? Or whether it makes sense to make a model with many elements. So to create a new element for each tested thickness (with the tested thickness) and then to create a model with many different elements. Or is that too time-consuming? |
elements, meshing, thickness |
using setFields to assign different material properties | Saleh Abuhanieh | OpenFOAM Programming & Development | 6 | April 19, 2022 09:37 |
Domain Reference Pressure and mass flow inlet boundary | AdidaKK | CFX | 75 | August 20, 2018 05:37 |
Adding material to CFX material library | marlon | CFX | 2 | October 16, 2016 09:33 |
Best Meshing scheme for Cylinder | Nutrex | Main CFD Forum | 4 | July 29, 2008 11:03 |
Volume Meshing & Face Meshing? singularity of grid | ken | FLUENT | 0 | September 4, 2003 11:08 |
