FSI coupling simulation in SLURM Cluster
Old   December 14, 2018, 17:51
Default FSI coupling simulation in SLURM Cluster
Claudio.M is on a distinguished road
Hello There,
I'm new in this kind of work, I'm trying to set the .sh script to run a ansys coupled simulation on a SLURM cluster.
I was wondering if anyone have an example in which there is the connection between the different solvers.
I have 5 files:
Coupling .sci
Structural .dat
Fluent .cas.gz
Journal .jnl
Script.sh
Unfortunately, I did find anything on internet that can explain me the correct way in which write the commands.
Thank you in advance for the help!
Claudio.M is offline   Reply With Quote
Old   January 7, 2019, 01:49
Svetlana Tkachenko
Svetlana is on a distinguished road
http://xansys.org/forum/viewtopic.php?p=95557 This suggests first you need to start workbench coupling program then fluent. If you are using slurm then creation of the SERVERFILE may or may not be unnecessary. What have you tried so far? Do you have a small test case -- a small example project which is coupled -- that I could try running to identify the exact command(s) to use?
Svetlana is offline   Reply With Quote
i ansys fsi hpc
Time dependent piezoelectric actuation voltage with system coupling for 2 way fsi Francis Hauris ANSYS 0 April 1, 2018 23:23
Cluster FSI shared Licenses Calumnt27 ANSYS 1 June 5, 2017 08:34
My FSI simulation (pipe-flow) vitorspadeto OpenFOAM Programming & Development 1 September 24, 2014 18:27
FSI Simulation of a 2D airfoil marcanyada CFX 13 July 3, 2014 10:23
Restart of FSI simulation V. Kumar CFX 3 July 20, 2006 14:23
