FSI Importing Pressure Error
Old   December 4, 2018, 15:15
Default FSI Importing Pressure Error
Nick Thomas
nick.l.thomas is on a distinguished road
I'm trying to import my pressure load from CFX to Static Structural but every time I "Import Load", my progress bar says:
"Mapping and Interpolating data for the selection (progress not available)...", progress is halted, and a PostEngine.exe window pops up. I've tested out the FSI feature with a simpler case without any issues, so I'm not sure what could be causing the problem here.
nick.l.thomas is offline   Reply With Quote
Old   December 9, 2018, 05:51
Unhappy Same problem
王莹
Alisa_W is on a distinguished road
Hello, Have you solved this problem? I met the same problem yesterday and tried several ways. However, it cannot be solved /-_-
Alisa_W is offline   Reply With Quote
Old   December 9, 2018, 16:24
Nick Thomas
Hi, I actually did! I needed to delete and relink the solutions. Then when I import the pressure load I still get the "Mapping and Interpolating data for the selection (progress not available)..." message, but without the .exe popping up. I guess this is typical and you just need to wait it out from here (it took a long time to import for my simulation). It seems like it isn't working since the progress bar does not change (hence the message) but eventually it loaded for me!
Old   December 9, 2018, 23:14
Smile
王莹
Thank you so much! Maybe I should also wait for it.
Old   December 9, 2018, 23:15
Smile
王莹
Thank you so much! Maybe I also need to wait for it.
error, fsi, postengine
long error when using make-install SU2_AD. tomp1993 SU2 Installation 3 March 17, 2018 07:25
DPM udf error haghshenasfard FLUENT 0 April 13, 2016 07:35
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 10:31
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 19:44
How to get the max value of the whole field waynezw0618 OpenFOAM Running, Solving & CFD 4 June 17, 2008 06:07
