Nusselt number or heat flux along a pipe wall |
December 3, 2018, 12:04 |
Argenis
Rep Power: 8 |
Hello everyone, I'm simulating a double pipe counterflow heat exchanger (2D axisymetrical), my thermal boundaries conditions are inlet temperatures, and I want to get heat flux along the pipe to then calculate Nusselt number along the pipe. I'm not trying to find the total heat flux, I want to get heat flux at every x location (along the pipe), and then calculate Nusselt number at every x location (along the pipe). Is there anyway I can get this? Again, I'm not trying to get what you find in heat transfer literature, where Nu sub x is Nusselt number untill that x location, I want to get Nusselt number AT that x location in this way: q=h*ΔT ; Nu= hD/k; Nu= q*D/(ΔT*k) So, if I can get heat flux (q) at any x location I would be able to find Nusselt number at any x location along the pipe. That's what I have in mind, and I would like to know if this is possible. (No matter if I have to use a UDF). |
December 6, 2018, 13:18 |
Erik
Rep Power: 23 |
Check out the FAQs:
https://www.cfd-online.com/Wiki/Ansy...ficient_in_CFX |
December 6, 2018, 13:47 |
Argenis
Rep Power: 8 |
Can I do that in fluent? I don't know much cfx
December 11, 2018, 22:41 |
#4 | |
December 14, 2018, 16:37 |
Lucky
Rep Power: 66 |
The surface heat flux is readily available is it not?
But since Nusselt number isn't a field variable, you do have do something special to convert the heat flux into Nusselt number. I.e. export it out of Fluent and then calculate it, or you must use a udf to calculate it within Fluent. |
December 14, 2018, 16:51 |
#6 | |
Argenis
Rep Power: 8 |
Yes, I'm going to get heat flux this way: q= k*dT/dY, and then Nusselt Number (out of fluent). I have only one doubt, dT/dY is calculated as dT/dR when the axisymmetric condition is enabled? |
December 14, 2018, 19:25 |
heat exchanger two fluids, nusselt local |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 92 | May 21, 2024 08:56 |
[Other] Can't Shake Erros: patch type 'patch' not constraint type 'empty' | BrendaEM | OpenFOAM Meshing & Mesh Conversion | 12 | April 3, 2022 19:32 |
Natural convection in a closed domain STILL NEEDING help! | Yr0gErG | FLUENT | 4 | December 2, 2019 01:04 |
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field | xiexing | CFX | 3 | March 29, 2017 11:00 |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 16:03 |
