November 24, 2018, 13:31 |
Lift Distribution over wing surface
Pranav
Hi!
I am a beginner to ansys ICEM CFD.I want to find the spanwise lift distribution over wing surface for my academic project work.The step starts with finding pressure over top and bottom surface of the wing.And this has to go with analyzing pressure distribution over different location of span. This can be done by finding pressure coefficient by defining different points on the wing surface. My question is in flow field how flow parameters can be determined at a point. How to define that point of interest where flow parameters have to be determined ?? And how to see the solution ?? |
November 30, 2018, 10:49 |
Lucky
Rep Power: 66 |
Sounds like you want to fly while you are still learning how to crawl. ICEM is a mesher. ICEM won't give you anything other than a mesh. You need a solver like Fluent or CFX.
Do some tutorials or whatever so you can hit the calculate button and get a solution. Once you get here, then you can come back and ask how to create a plot. |
lift distribution., pressure coefficients |
3D Wing Analysis | Ed | FLUENT | 5 | April 13, 2019 13:07 |
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 11:05 |
Lift and drag coefficients of a flapping wing aircraft | Julian121 | FLUENT | 36 | August 24, 2012 19:37 |
[ICEM] Automatic mesh generation script surface intersection problem | stuart23 | ANSYS Meshing & Geometry | 0 | May 13, 2011 01:10 |
Lift and Drag on airplane wing | Arj | CFX | 4 | October 6, 2006 04:05 |
