Calculating the frequency of the strain in ANSYS Explicit Dynamics
Old   November 15, 2018, 00:41
Default Calculating the frequency of the strain in ANSYS Explicit Dynamics
Workbencher is on a distinguished road
I was trying to simulate a metal ball drop in Explicit Dynamics.
I was able to model the ball drop and was able to model the strain which occurs at the ball drop.
I had a couple of questions on this
1. I wondering if there was any means to calculate the frequency of the ball drop. I was trying an approach with which the maximum and the minimum time steps can be calculated and the frequency can be obtained from them. In order to change the maximum and minimum time steps from Analysis settings in Explicit dynamics I tried to change that from program controlled to a time of my choosing. However it returned with an error. I was wondering if it would be possible to calculate the frequency or somehow change the time steps in this approach, or is there any other way to calculate the frequency.
2. Also is there any way to generate the waves which are propagating through the structure.
Workbencher is offline   Reply With Quote
analysis settings, ansys, explicit dynamics
Calculating Coefficient of Drag in ANSYS Fluent osamaghani FLUENT 16 April 21, 2019 11:29
Pro/E to ANSYS Parameterization Guide Trues ANSYS 4 April 18, 2018 06:52
calculating Pressure Drop in a channel in Ansys ZGM67 Main CFD Forum 0 April 18, 2011 06:31
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 18:27
Calculating shedding frequency of square cylinder zonexo Main CFD Forum 5 November 17, 2005 19:12
