Mesh motion vs. Frame motion Small-Wind turbine |
November 8, 2018, 16:01 |
Rafael Radtke
Hey guys,
I'm simulating a 3d small wind turbine (1,5m diameter) using two ways. When I simulated the turbine in Steady state using Frame motion I got the result of 11 Nm for the turbine Torque When I simulated the turbine in Transient state and using Mesh motion I got the result of 9 Nm for the turbine (after the simulation stabilize). Does anyone knows if this is a problem or it could really happen? Thanks |
November 14, 2018, 03:16 |
Gert-Jan
Rep Power: 28 |
You need to compare with experiments.
Which software did you use? In CFX, I found differences, although mostly not this large. But it depends on the operation condition and the geometry. So impossible to say....... |
cfd, frame motion, mesh motion, transient, wind turbine |
Single moving reference frame vs Multiple reference frame for Wind Turbine CFD | mrswordf1sh | FLUENT | 4 | January 25, 2020 08:43 |
variable pitch vertical axis turbine mesh motion | bolus13 | CFX | 5 | November 1, 2016 16:49 |
Star CCM Overset Mesh Error (Rotating Turbine) | thezack | Siemens | 7 | October 12, 2016 11:14 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
Moving reference frame in wind turbine | kongl1986 | FLUENT | 0 | March 30, 2013 10:50 |
