November 2, 2018, 17:52 |
Two phases - different inlets
sandy
Rep Power: 13 |
Hi all,
I have two inlet boundaries next to each other. 1. On one I specify Mass flow for primary phase and set 0 for the other 2. On the other I set Pressure inlet which should only allow secondary phase. For this I gave pressure inlet with volume fraction of secondary phase set to 1. Is this the correct way of doing it ? |
November 6, 2018, 17:29 |
#2 | |
Lucky
Rep Power: 66 |
Yes that works.
Just a tip so you don't confuse others later. Actually you don't specify the mass flow for only the primary phase. You are specifying the mass flow for everything entering that boundary. And then you also specify that secondary phase is none. That's two different boundary conditions. In the same way, you don't say phase-1 has a pressure and temperature and phase-2 is at a different pressure and temperature. |
November 8, 2018, 10:23 |
#3 | |
sandy
Rep Power: 13 |
Problem in Multiphase setup with phases | NiBa | FLUENT | 4 | December 2, 2023 04:42 |
Mass transfer UDS between two phases | rarnaunot | FLUENT | 1 | June 25, 2018 08:22 |
multiphaseEulerFoam: PtrDictionary<phaseModel> phases_ of multiphasesystem fluid | maybee | OpenFOAM Programming & Development | 9 | January 27, 2014 07:24 |
Two pressure inlets problem | Medison | CFX | 1 | August 22, 2012 07:50 |
Multiple Inlets | Charlie V | FLUENT | 0 | May 28, 2001 03:29 |
