October 27, 2018, 12:35 |
Vertical Wind Turbine , Fluent or CFX ?
Shefo
So I was working on a graduation project with 5 other colleagues and we chose the project to be about a Vertical axis wind turbine but we are beginners in the CFD field so Which solver should we use that would be best for a vertical wind turbine ?
and can you please recommend us any good comprehensive tutorial on how to start learning and using Ansys ? Thanks in advance , Shefo |
July 17, 2022, 12:50 |
Prakhar Yadav
Rep Power: 6 |
What solver did you used ? |
July 17, 2022, 17:56 |
Gert-Jan
Rep Power: 28 |
CFX is made for rotating machinery. So I would recommend tat one.
vawt |
Need to output surface pressure on blades in a vertical axis wind turbine | kmallick | OpenFOAM Post-Processing | 1 | October 22, 2018 00:08 |
Wind turbine rotation through UDF in FLUENT | Shamoon Jamshed | Fluent UDF and Scheme Programming | 10 | June 25, 2018 13:58 |
Vertical Axis Wind Turbine UDF Advice | MechEng86 | Fluent UDF and Scheme Programming | 0 | June 11, 2016 07:41 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 23:56 |
regarding fluent setup for wind turbine analysis | er_ijaz | FLUENT | 0 | May 1, 2013 05:55 |
