Centrifugal Blower - CFD Tutorial - Multiple Reference Frame |
October 12, 2018, 00:44 |
mayur
Rep Power: 8 |
This tutorial illustrate the procedure for setting up and solving problem using the MRF capability. As an example, the flow field on a 2D section of a centrifugal Blower will be calculated. Although this is a general methodology that can be applied to cases where more than one reference frame is moving, this example will be limited to a single rotating reference frame.
This tutorial demonstrates how to do following..... 1. Create mesh interface. 2. Specify different frames of reference for different fluid zones. 3. Set the relative velocity of each wall. 4. Calculate a solution using the pressure - based Solver. |
Second Derivative Zero - Boundary Condition | fu-ki-pa | OpenFOAM | 11 | March 27, 2021 04:28 |
problem with turbulence models after compilation? | lfgmarc | OpenFOAM Programming & Development | 19 | November 20, 2013 00:50 |
how to treat the rotating zone in multiple reference frame (MRF) | Jiuan | FLUENT | 4 | May 24, 2010 21:58 |
G95 + CGNS | Bruno | Main CFD Forum | 1 | January 30, 2007 00:34 |
Building OpenFoAm on SGI Altix 64bits | anne | OpenFOAM Installation | 8 | June 15, 2006 09:27 |
