there is a leak in the mesh in ICEM
Old   October 8, 2018, 23:46
Post there is a leak in the mesh in ICEM
rbwally
rbwally is on a distinguished road
hey guys,
recently i am using ANSYS ICEM to generate a volume mesh in the bottom-up way, firstly i generate the surface mesh(mesh type all tri, mesh method dependent), secondly i generate the volume mesh from the above surface mesh by QUICK(Delaunay). Consequently, there comes a error that:there is a leak in the mesh, material point fluid.flow can reach material solid.inport.
how can i solve this ?
thanks in advance
rbwally is offline   Reply With Quote
Old   October 9, 2018, 03:57
Gert-Jan
Gert-Jan will become famous soon enough
1) Better ask in the Geometry & meshing forum.
2) Did you set the values for Triangulation and Topology tighter (factor 10 smaller)? See Settings>Model (somewhere, out of my head). Try that first.
3) Did you try the Robust (Octree) method? This allows you to find the holes and repair them, either in the meshing, or at least gives you an indication where the CAD is inapropriate.
Gert-Jan is offline   Reply With Quote
Old   October 9, 2018, 04:11
rbwally
thank you Gert-Jan for your reply.
2)i will have this tried later.
3)the Robust(octree) method has been tried, as the element number generated via this method is so many and the long time it takes, finally i have this method abandoned.
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
Gambit problems Althea FLUENT 22 January 4, 2017 04:19
ICEM of ANSYS V15: how to export .msh mesh for CFX hydroaero CFX 1 March 9, 2015 23:15
[ANSYS Meshing] Question about ICEM mesh output to CFX lnk ANSYS Meshing & Geometry 0 July 27, 2012 16:39
Boddy fitted Hexcore Mesh in ICEM Cfd Mitch CFX 0 December 29, 2008 07:07
