Ansys Workbench-Meshing scripting
Old   October 2, 2018, 12:24
Default Ansys Workbench-Meshing scripting
Nathan
njpatter is on a distinguished road
Hi everyone,
First, thanks for all of the great answers to previous questions that people have provided in the forum, they have been helpful in navigating the scripting/automation process.
I am trying to automate an entire project:
1. Geometry creation in SpaceClaim
2. Sizing and mesh generation in Meshing
3. Fluent setup, simulation, and post-processing
I have a working solution for #1 and am figuring out the command list options for #3. I also have a working solution for Meshing (#2), well two of them actually, but am unable to figure out how to call either from a Workbench journal file.
The one I'd prefer to use at this point is a working jscript macro for Meshing and I would like to call from a workbench journal.
Simple version of Meshing Macro (works if called by running Macro in Meshing):
Main();
function Main()
	var Mesh_Mod = DS.Tree.FirstActiveBranch.MeshControlGroup;
	DS.Script.SelectItems(""+Mesh_Mod.ID);
	//Insert the face sizing for the object
	DS.Script.doInsertMeshSize(1)
	ListView.ActivateItem("Scoping Method");
	ListView.ItemValue = "Named Selection" ;
	ListView.ActivateItem("Named Selection");
	ListView.ItemValue = "ObjSurface" ;
	ListView.ActivateItem("Type");
	ListView.ItemValue = "Element Size";
	ListView.ActivateItem("Element Size");
	ListView.ItemValue = "0.01";
	ListView.ActivateItem("Behavior");
	ListView.ItemValue = "Hard";
When I try to run it from a Workbench journal file using:
meshComponent1 = system1.GetComponent(Name="Mesh")
meshComponent1.Refresh()
meshing1 = system1.GetContainer(ComponentName="Mesh")
meshing1.Edit()
meshScript = open('C:\...blahblahpath...\Meshing_ScriptTest.js', 'r')
meshing1.SendCommand(Command=meshScript.read()) #this is line 20
meshing1.Exit()
It launches the Meshing program and then throws the following error:
CommandFailedException: Unalge to update setup using new parameter values. In file '...myfilepath...', line 20
Does anyone have any suggestions where my code/approach may be wrong?
njpatter is offline   Reply With Quote
Old   October 2, 2018, 13:34
Nathan
I figured it out and thought I'd leave it here in case anyone else has the same problem.
Instead of the open and SendCommand lines from above, I used this:
meshing1.SendCommand(Command="WB.AppletList.Applet ("DSApplet").App.Script.doToolsRunMacro("C:/folder/structure/withForward/slashes/Meshing_ScriptTest.js")")
and exiting I did a meshComponent1.Update() instead of refresh.
Old   March 22, 2023, 09:47
lbj007 is on a distinguished road
Hi, I would like to ask a question about scdm scripting. I want to filter out all the faces such as in the z = 5 plane, but I do not know how to implement this process.
lbj007 is offline   Reply With Quote
ansys workbench meshing sanjaykummar2810 CFD Freelancers 6 August 15, 2018 01:47
Ansys workbench scripting sunilpatil CFX 7 January 31, 2018 07:57
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing David-CFD ANSYS Meshing & Geometry 1 April 1, 2011 06:22
Meshing In Ansys Workbench For Fluent (Refinement) FAU_OceanEng FLUENT 0 May 31, 2010 18:12
