Parameter set output from first block as input to another
Old   October 1, 2018, 04:56
Default Parameter set output from first block as input to another
Qbz
Jakub
Qbz is on a distinguished road
I need to do a structural analysis of an assembly for which I have already made a steady stade thermal analisys. I have created many design points in the parameters table and I would like to use all of them to the structural analysis, but I actually have no idea how to use more than just first. Is this possible? If yes please tell me how.
Thank you.
Cheers,
Kuba
Qbz is offline   Reply With Quote
Old   May 1, 2024, 06:21
Default dublicate the block
mahir şahin
mahir is on a distinguished road
as i understand from what you write, you should duplicate the analysis block in order to use same mesh structure and same setup loadings. whhen you do this, the parameters you have created previousaly will also valid for the new analysis blocks...
mahir is offline   Reply With Quote
Using output parameter as input parameter within the same simulation jjfm20 FLUENT 11 November 6, 2017 09:53
How can i assign a set of data (table or matrix) as an input for source term? reza.s CFX 5 March 2, 2015 21:31
writing execFlowFunctionObjects immortality OpenFOAM Post-Processing 30 September 15, 2013 07:16
[Commercial meshers] Icem Mesh to Foam jphandrigan OpenFOAM Meshing & Mesh Conversion 4 March 9, 2010 03:58
How to set environment variables kanishka OpenFOAM Installation 1 September 4, 2005 11:15
