[Mechanical] Same settings, different results?
Old   September 10, 2018, 17:36
Default [Mechanical] Same settings, different results?
sheaker's Avatar
Oskar
sheaker is on a distinguished road
Hello. I'm trying to recreate simulation setup for further changes but I cannot get convergence on recreated setup. I am doing same setup but divergence occurs. So i compare logs and there is only one different line in log.
Converged solution:
 DELETE RESTART FILES OF ENDSTEP
 ******************* SOLVE FOR LS 1 ****************
 PRINTOUT RESUMED BY /GOP
 SELECT       FOR ITEM=TYPE COMPONENT=
  IN RANGE         9 TO          9 STEP          1
          1  ELEMENTS (OF       8810  DEFINED) SELECTED BY  ESEL  COMMAND.
 APPLIED BOUNDARY CONDITIONS OR FORCES FOR JOINT ELEMENTS
SPECIFIED VALUE FOR SELECTED ELEMENT
 ELEMENT NUMBER                                =     0
LINEAR OR ANGULAR VELOCITY LABEL               = OMGZ
SET ACCORDING TO TABLE PARAMETER              = _LOADVARI152
Diverged solution:
 ELEMENT NUMBER                                =     0
SET ACCORDING TO TABLE PARAMETER              = _LOADVARI70
The only difference in settings is that geometry is imported in workbench from first structural analysis to second structural analysis.
What is _LOADVARI70 /_LOADVARI152 ?
Can I change something to make both simulation converged?
Regards,
Oskar
sheaker is offline   Reply With Quote
Save Results automatically by APDL Command ansyxyz ANSYS 1 June 5, 2018 09:16
Difference in results with different "Processing options" (Core) Elmo11 ANSYS 0 July 17, 2017 14:34
Lift and Drag coeff change with V 16 and 13 PISO for same mesh file and same settings arunraj FLUENT 0 June 2, 2016 23:43
error in Setup and Results cuteapathy FLUENT 9 June 19, 2012 13:16
Transient Run - Output "Time" in partial results? evcelica CFX 2 May 16, 2012 22:36
