August 14, 2018, 10:23 |
ANSYS Forte
I am currently working on my masters project and I have been facing a problem which involves the timestep of the simulation.
The project is a simulation for a range of piston designs to determine the best out of the profiles, the settings of the models have been based on a previous experiment paper. Basically the injection model is with a square profile and injects for a duration of 0.18 degrees (1.5ms). The timestep I have set currently is Initial 5E-7 and maximum 5E-6. The problem coming up is that whenever the crack angle is where the injection starts, the timestep drastically minimizes to E-8 and continues to do so until it fails due to time step being too small. I would like to ask if there is a way to work around this or if there is a way to set the minimum timestep. Thanks in advance |
ansys forte, timestep |
Running Ansys in BAtch Mode | kuleuvenstudent | ANSYS | 1 | October 18, 2017 12:11 |
[ANSYS Meshing] ANSYS mesh - I was surprised... | assafwei | ANSYS Meshing & Geometry | 0 | September 4, 2014 12:17 |
Ansys HPC licensing policy | assafwei | ANSYS | 0 | June 29, 2014 16:00 |
Using ICEM CFD to repair/edit ANSYS Meshing | Kaaji1359 | ANSYS | 2 | July 30, 2013 10:28 |
Exporting results from CFX to ANSYS ?? | sohail ahmed | CFX | 1 | December 20, 2007 01:10 |
