Error in pressure import to mechanical from fluent |
August 14, 2018, 04:39 |
Pravil C Prakash
Rep Power: 8 |
Hi
I am trying to do coupled analysis with fluent and mechanical for a rotating propeller for finding the blade stresses. In fluent the settings are transient, pressure based, k epsilon model with mesh motion. I used same geometry with both fluid volume and actual solid blade. After running transient analysis in fluent the pressure is imported to mechanical, but the source points of blade in fluid volume were in angular offset to actual solid blade. Only a part of pressure is correctly transferred to the blade area. How to solve this problem ? |
fluent, import, mechanical, pressure |
Wind tunnel Boundary Conditions in Fluent | metmet | FLUENT | 6 | October 30, 2019 13:23 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 14:41 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 23:56 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 21:30 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 16:00 |
