Forces on Radiator
Old   August 4, 2018, 06:39
Default Forces on Radiator
Deutschland
Horsepower is on a distinguished road
for my Bachelor thesis I want to model a radiator from a fromula student race car in FLUENT. I've allready implemented the radiator as a porous region and defined the viscous resistance coefficient (1/alpha) and the intertial resistance coefficient (C_2).
The flow field is showing good results in terms of the pressure drop and the velocity through the radiator seems to be modeled correctly. My problem is, that the force on the radiator is still calculated as to be zero. What do I have to do that FLUENT can calculate the force witch is operating on the radiator?
In advance, many thanks for the support.
Lukas
Horsepower is offline   Reply With Quote
Old   August 11, 2018, 16:06
Rodrigo
rrdop is on a distinguished road
I am in a similar situation but with a different problem, I am working on my FSAE team Sidepod and I’m trying to put the radiator on the simulation, but the flow don’t go through the porous media, it’s like my contact region was a wall zone. How do you set your simulation? Did you got any problem like these?
rrdop is offline   Reply With Quote
fluent, force coefficients, porous media
Wrong forces coming from forces function object in controlDict Jason_Duguay OpenFOAM Post-Processing 0 April 13, 2016 10:07
Pressure and density values to compute forces fernexda OpenFOAM Post-Processing 2 March 6, 2015 04:39
Forces for airfoil test case Martin_ OpenFOAM Running, Solving & CFD 1 July 2, 2012 12:58
FORCES don't run! C12Carbon OpenFOAM 0 September 10, 2011 08:34
Valve Forces in CFdesign Mike Clapp Main CFD Forum 3 March 8, 2001 15:09
