ANSYS Aqwa ECAT/NCEL/COMP Error
Old   August 1, 2018, 18:46
Default ANSYS Aqwa ECAT/NCEL/COMP Error
Jordan
Jtmannnn18 is on a distinguished road
I am currently working on a simulation in Aqwa which models a vertical fully submerged SONAR device with a point buoyancy at the top. It has 7 cylindrical sensors (modeled as a single structure each), and they are connected by 6 catenary mooring lines [referred to as tube]. There is a seventh mooring line goes from the bottom of the 7th structure down to a fixed point on the seabed [referred to as chain]. Each of the lines is one single catenary section with 100 elements and a length that is exactly the distance of separation between the connection points.
After I modeled all of that and I ran a static stability response module, I got these errors:
EXPECTED A -ECAT- CARD. GOT A -NCEL
COMPOSITE(ECAT) BETWEEN STRUCTURES NOT UNIQUE
TOO FEW/MANY ECAT CARDS FOR PREVIOUS COMP CARD
LENGTH OF UNITY IS SMALLEST VALUE ALLOWED
From my research so far, it seems that this is definitely an issue with the catenary data. As far as what, exactly, is wrong and how to fix it I am stumped. Any help or ideas would be appreciated.
Thanks,
Jordan
Jtmannnn18 is offline   Reply With Quote
ansys, aqwa, cable, catenary, mooring
[OpenFOAM] an error in Calculator's equation immortality ParaView 12 June 29, 2021 01:10
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 01:21
Compile calcMassFlowC aurore OpenFOAM Programming & Development 13 March 23, 2018 08:43
long error when using make-install SU2_AD. tomp1993 SU2 Installation 3 March 17, 2018 07:25
How to get the max value of the whole field waynezw0618 OpenFOAM Running, Solving & CFD 4 June 17, 2008 06:07
