Help with this ANSYS error
Old   July 31, 2018, 20:53
Exclamation Help with this ANSYS error
Moeda Verde
Moedinha is on a distinguished road
I installed the Student version of ANSYS 19.1 but when i tried launch I get this message:
An unexpected error has occurred: The following required addins could not be loaded: Ans.SceneGraphChart.SceneGraphAddin. The software will exit.
--- System.AggregateException: The following required addins could not be loaded: Ans.SceneGraphChart.SceneGraphAddin. The software will exit.
--- System.Exception: SceneGraph.Engine - failed to boot up.
at Ans.SceneGraphChart.Engine..ctor(IConfiguration p_config, IErrorHandler p_errorHandler)
at Ans.SceneGraphChart.SceneGraphAddin.Load(AddinLoad Context context)
at Ansys.Core.Addins.AddinManager.setupAddin(String path, String name, AddinBase addin)
at Ansys.Core.Addins.AddinManager.LoadAddin(String name, String path)
I searched everywhere on the internet but this problem seems new.
Moedinha is offline   Reply With Quote
Old   November 3, 2018, 19:26
frank2243 is on a distinguished road
Did anyone have ever found a solution for this problem?
I have Windows 10 installed on an iMac 5K with the latest AMD drivers.
frank2243 is offline   Reply With Quote
Old   April 25, 2021, 06:51
Default HELP error opening workbench ANSYS 2020R1
learning
aifo is on a distinguished road
I've downloaded ansys 2020r1 and follow every step but I receive the same error when I open the workbench >>
please someone know how to solve this problem!_
aifo is offline   Reply With Quote
Old   March 7, 2024, 10:03
ali hozhabr
ali82 is on a distinguished road
do you find any solution to this problem?
I have the same problem in Ansys 19.3
ali82 is offline   Reply With Quote
ansys 19.1, error, launching, problem
[OpenFOAM] an error in Calculator's equation immortality ParaView 12 June 29, 2021 01:10
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 01:21
Compile calcMassFlowC aurore OpenFOAM Programming & Development 13 March 23, 2018 08:43
long error when using make-install SU2_AD. tomp1993 SU2 Installation 3 March 17, 2018 07:25
How to get the max value of the whole field waynezw0618 OpenFOAM Running, Solving & CFD 4 June 17, 2008 06:07
