July 31, 2018, 13:17 |
Output parameters along a path
Richard L
Rep Power: 9 |
Hi folks,
I am currently performing some forward modelling in a transient thermal model in Mechanical. Here I simulate the effect of an ice age on a large cube of rock to conclude on the local heat flow from the deeper earth. Therefore, I vary the heat generation in the rock as well as the heatflux from my base boundary. I want to compare the modelled heat flux and temperature along a specific path with my borehole data (model path = bore hole trajectory). So here's my problem. So far I have created a solution property for temperature and total heat flux along the borehole path, which gives me exactly the plots I am after: Depth vs Temp / Depth vs. heat flux. However, I can address this plot as an output parameter. In Ansys mechanical I cannot only set the 'P' to parameterise on minimum and maximum values, which works. Exporting the plot results by hand via the right-click export obtion seems a bit laborious for the wast amount of models I am running.. Can anyone relate to this issue and is there a potential workaround to it? Many thanks for your answers! Cheers, Rich |
Pro/E to ANSYS Parameterization Guide | Trues | ANSYS | 4 | April 18, 2018 06:52 |
how to plot graph for output parameters using UDF? | ned.musab | Fluent UDF and Scheme Programming | 0 | October 29, 2017 08:23 |
Setting up additional convergence criteria: output parameters are ‘constant’ | Pierre1 | FLUENT | 3 | March 23, 2015 10:47 |
Setting up additional convergence criteria: output parameters are ‘constant’ | Pierre1 | CFX | 3 | March 21, 2015 05:47 |
Questions about data output | aki_yafuji | OpenFOAM Running, Solving & CFD | 3 | September 9, 2010 02:59 |
