Alexander Kibbe
Rep Power: 8 ![]() |
OK so i wrote some code. The idea is to apply a load and them move it with time. The applying a load part works fine but the moving part doesn't
Project file is attached, you can see the code blocks (each is separate so i just suppress them) specifically the code that is failing to move over time is the below. Does anyone know why its not working. ! Commands inserted into this file will be executed just prior to the ANSYS SOLVE command. ! These commands may supersede command settings set by Workbench. ! Active UNIT system in Workbench when this object was created: Metric (mm, kg, N, s, mV, mA) ! NOTE: Any data that requires units (such as mass) is assumed to be in the consistent solver unit system. ! See Solving Units in the help system for more information. ! Create heat function on global CS (0) *DIM,HEAT_FLX,TABLE,6,23,1,,,,12 ! The last number corresponds to the ID number for the coordinate system ! ! Begin of equation: B*exp(-2*(SQRT({X}^2+{Y}^2)/w)^n) ! *SET,HEAT_FLX(0,0,1), 0.0, -999 *SET,HEAT_FLX(2,0,1), 0.0 *SET,HEAT_FLX(3,0,1), 0.0 *SET,HEAT_FLX(4,0,1), 0.0 *SET,HEAT_FLX(5,0,1), 0.0 *SET,HEAT_FLX(6,0,1), 0.0 *SET,HEAT_FLX(0,1,1), 1.0, -1, 0, 0, 0, 0, 0 *SET,HEAT_FLX(0,2,1), 0.0, -2, 0, 1, 0, 0, -1 *SET,HEAT_FLX(0,3,1), 0, -3, 0, 1, -1, 2, -2 *SET,HEAT_FLX(0,4,1), 0.0, -1, 0, 2, 0, 0, -3 *SET,HEAT_FLX(0,5,1), 0.0, -2, 0, 1, -3, 3, -1 *SET,HEAT_FLX(0,6,1), 0.0, -1, 0, 2, 0, 0, 2 *SET,HEAT_FLX(0,7,1), 0.0, -3, 0, 1, 2, 17, -1 *SET,HEAT_FLX(0,8,1), 0.0, -1, 0, 2, 0, 0, 3 *SET,HEAT_FLX(0,9,1), 0.0, -4, 0, 1, 3, 17, -1 *SET,HEAT_FLX(0,10,1), 0.0, -1, 0, 1, -3, 1, -4 *SET,HEAT_FLX(0,11,1), 0.0, -1, 16, 1, -1, 0, 0 *SET,HEAT_FLX(0,12,1), 0.0, -3, 0, 5, 0, 0, -1 !W=beamwidth *SET,HEAT_FLX(0,13,1), 0.0, -4, 0, 1, -1, 4, -3 *SET,HEAT_FLX(0,14,1), 0.0, -1, 0, 10, 0, 0, -4 !n=order *SET,HEAT_FLX(0,15,1), 0.0, -3, 0, 1, -4, 17, -1 *SET,HEAT_FLX(0,16,1), 0.0, -1, 0, 1, -2, 3, -3 *SET,HEAT_FLX(0,17,1), 0.0, -1, 7, 1, -1, 0, 0 *SET,HEAT_FLX(0,18,1), 0.0, -2, 0, 2000000, 0, 0, -1 !B=power *SET,HEAT_FLX(0,19,1), 0.0, -3, 0, 1, -2, 3, -1 *SET,HEAT_FLX(0,20,1), 0.0, 99, 0, 1, -3, 0, 0 ! ! End of equation: B*exp(-2*(SQRT({X}^2+{Y}^2)/w)^n) !--> xpos=-15 ypos=0 zpos=0 xrot=-90 yrot=0 zrot=0 time_step_size=5 time_now=0 *do,i,0,5 local,12,CART,xpos+5*i,ypos,zpos,zrot,xrot,yrot sf,top,hflux,%HEAT_FLX% kbc,1 ! ramped loading time_now=time_now+time_step_size time,time_now ! specify time at the end of load step autots,on ! use automatic time-stepping deltim, time_step_size/5, time_step_size/10, time_step_size/2, on lswrite,i+1 !sfdele,all,all *enddo |
apdl, load, loop, move |
Modeling a Vehicle load moving on a simply supported bridge with one span in 3D | Adi_ | Structural Mechanics | 0 | June 14, 2018 03:36 |
Get load values at each substep | ploi | ANSYS | 0 | March 10, 2016 15:07 |
Cfd to ansys thermal to ansys structural interface | ssixr | ANSYS | 17 | July 31, 2015 15:18 |
[Other] How to set up a dynamic mesh for a piston moving through a tube of variable diameter? | karkar | OpenFOAM Meshing & Mesh Conversion | 0 | July 4, 2012 06:54 |
moving load problem | aditi chauhan | ANSYS | 0 | October 9, 2010 04:47 |
